fuel pump number
Old Mar 24, 2016 | 06:19 AM
dieselvoyager's Avatar
What dos you Mporp valve value tell you ?
had ones a 2001 with metal parts in the filter and it turn out the electric pump in the fuel filter was faulty still running before start but was noisy.
The electric pump is after the fuel filter and if it fails you will get metal objects in HP pump and injectors.
The electric pump left some metal parts in the HP pump and a small part in the mprop valve , and the valve was stuck (Mprop valve is the one controling the diesel pressure)
Old Mar 24, 2016 | 06:21 AM
2.5 & 2.8 HP pump is equal
Old Mar 24, 2016 | 06:23 AM
Old Mar 24, 2016 | 01:45 PM
shaky's Avatar
where is the mprop valve , i have got a complete fuel filter housing from breakers going to change it next week
Old Mar 24, 2016 | 01:47 PM
  #15
shaky's Avatar
its ok i have it , i changed that a couple of weeks ago the one that bolts to the hp pump
Old Mar 25, 2016 | 05:54 AM
  #16
Shaky : Mprop valve is mount on HP pump just below alternator small round thing with a conector. If you detach servo oil container it easy to get access . You can't see if it's working with out a OBD read out.
See pic link . it's the round thing to the left.
Chrysler Forum - Chrysler Enthusiast Forums - dieselvoyager's Album: Voyager RG diesel Work Shop Pictures - Picture
Old Mar 25, 2016 | 05:55 AM
  #17
Did you get a reading or did you just change it ?
Lift pump is only running when you are starting when engine is running it stops !
Old Mar 25, 2016 | 02:16 PM
  #18
shaky's Avatar
i just changed it mate
Darth Menace
Feb 19, 2016 09:16 PM
bcacbe
Apr 30, 2015 03:07 PM
kkc
Oct 9, 2014 12:56 AM
96BTC
Sep 27, 2010 10:29 PM
adeel43
Sep 1, 2010 03:56 PM
