If anyone needs help in Surrey UK
Old Apr 26, 2010 | 09:17 AM
  #51
arnieboy's Avatar
Default 18in 300c wheels
hi,can anyone advise on fitting these wheels to my 98 3.3, i e do i need spacers/different wheel nuts......cheers newbie
Old May 4, 2010 | 04:12 AM
  #52
maz2010's Avatar
hi scruffy,
Gear change on my 51 crd voyager is a struggle. They are just stiff when trying to shift from 1 to the next. When in gear and pedal is down all the way, the car still tries to move and also vibrates a lot. I have had conflicting advise from mechanics, what is your opinion please. I am in Sussex, so not ar from you.
Old May 4, 2010 | 04:24 AM
  #53
glowplug's Avatar
You have a clutch problem, it is not disengaging properly. Could well be the master/slave cylinder, thrust bearing or clutch fork. You could get someone to watch the clutch fork whilst you slowly press the clutch pedal. If it starts to move immediately then it may be the fork or bearing. If it takes a while for the movement on the pedal to translate to movement on the fork then it is the master/slave.
Old May 6, 2010 | 03:55 AM
  #54
maz2010's Avatar
Thank you Glowplug. I will let you know how I get on.
alex1230
Jan 7, 2011 03:43 AM
svttour
Sep 24, 2010 02:48 AM
mike96jxi
May 18, 2010 12:24 AM
Scruffy
9
Sep 24, 2009 07:11 AM
cnixon
Jun 11, 2008 10:41 AM
