installing parrot bluetooth and dashcam
Old Aug 27, 2014 | 09:22 AM
dale_hopkinson's Avatar
Banned
Default installing parrot bluetooth and dashcam
Hi I'm about to install a Parrot mki9200 and a small dash cam with no screen.
Could someone please tell me where I would attach a mute signal and also where the speaker wires return from the amp for the phone calls (I'm going to use the aux in on the dvd for music).
While I'm doing this the satnav voice comes out of the left speaker (I'm assuming for lhd) so unless anyone knows of a setting I can change, Im thinking of swapping left and right channels around.
I am also installing a dash cam which has a motion sensor and I want to leave running 24/7. I've purchased a battery guard from Maplin which will cut off the supply at my chosen voltage. I'm thinking of wiring this into the feed to the left hand accessory socket which is marked as being connected directly to the battery (obviously fused). This means the socket will also be protected.
Is there a place further back I could install this that in particular would allow me to have the radio, dvd and screen powered without the key in the ignition but to cut out before the battery is drained (whilst retaining auto off when they key is first removed).
Thanks everyone
Old Aug 27, 2014 | 11:07 AM
Banned
2005+ voyager 3.3 Limited xs
Old Aug 27, 2014 | 01:03 PM
sjbilton's Avatar
Dale,
I fitted a MKi9200 into our 2006 2.8 GV, and just bought the right SOT lead for the car from a local car audio place for about £10.
It just goes between the wiring loom and the radio using the existing plugs, and provides the necessary wiring interface for the parrot - it all works a treat.
Steve
Old Aug 27, 2014 | 01:05 PM
Banned
Because ive got the factory amp the guy at halfords said the sot lead I needed was £49!
Old Aug 28, 2014 | 02:44 PM
AlanC is the man for Dash Cams on here check his threads.
Old Aug 28, 2014 | 05:01 PM
Banned
Thanks I'll have a look.
If someone knows the radio cable colours it would be very useful. Thanks
dale_hopkinson
May 5, 2022 03:21 PM
andyb2000
May 10, 2015 06:08 AM
Bob Angel
Dec 10, 2011 08:14 PM
BritPhil
Oct 7, 2011 02:51 PM
milesy_boy
Feb 15, 2011 05:11 AM
