04 sebring TRUNK is locked! need help! keys are in trunk!
Old Dec 14, 2018 | 12:21 AM
  #21
JessieVeliz's Avatar
Originally Posted by shnormo
The more pain in the *** way to do it is to take out the rear seat... it's been done before.
thank you for this post so much. I lost my keys and I have been using the spare. My spare was cut too short to fit the trunk and i thought the trunk release was broken. My trunk was full of my items and also my husbands items i was able to keep after he passed away. I was devastated. I dont have alot of money to go to dealer or get locksmith. I was able to get into the trunk with the knowledge you posted and i was able to retrieve the items. Thank you so much it's almost Christmas and this is all I wanted was to get the last of my husband items. I cant express my gratitude. Merry Christmas
Old Nov 28, 2021 | 05:54 PM
  #22
Misslisar's Avatar
Default Thank you! Thank you!
Originally Posted by tanmam
I just had to do this on a 2003 Sebring convertible , you need to remove the the interior light fuse...Should be a 10 amp....leave out for about 10 secs. Than put it back in....then hit your trunk button...Just worked for me half hour ago...hope it helps
OMG!!! The fuse in and out worked!!!!!! AAA couldn't even get it open. Thank you times 500!!!
Old May 25, 2022 | 12:28 PM
  #23
user 697820823's Avatar
Originally Posted by Peter Wood
My wife has the exact same model and was in the exact same situation just today. I found your post and was able to zip over and rescue her and the kids at the grocery store! Thank you!
O4? I’m giving it a shot. About the disconnecting battery connections. My battery is in fender well, guess they weren’t on that year? Or are you talking in fender well?
Old May 25, 2022 | 04:26 PM
  #24
ggoose's Avatar
Please check out this link. I have verified that pulling the IOD fuse for 2 minutes and inserting will activate the trunk button to the left of the steering wheel without the key being in the ignition.
You can disconnect the battery from the engine compartment. The red and black cables from the battery have mounting posts on drivers side. The easiest to disconnect is the black negative cable attached to a stud on the driver's side strut tower. Note these are also the points where you would attach the jumper cables in the event the battery has died.
https://www.chryslerforum.com/forum/...wn-help-33843/
Dee Bergs
Jun 14, 2019 02:02 PM
CincinnatiSebring
Sep 20, 2018 07:35 PM
74firemedic
May 16, 2011 09:22 AM
pascamel
May 29, 2010 08:45 PM
Beaker1941
May 13, 2008 05:28 PM
