2005 Pacifica 3.5 - Touring Oil Light
Old Jan 26, 2020 | 06:55 PM
  #21
UberPacifica2005's Avatar
Hey Thanks! I ran the codes again, having just replaced the purge valve and vacuum detection pump at the evap canister, and there are no evap codes.... just P0420 "threshold bank 1" Could an O2 sensor cause the "GasCap" dash code? My other worry is that I did not use Mopar parts and it now can't see the new parts. I have a new Mopar gas cap...
You mentioned exhaust, how would that effect the "gascap" dash code?
Thanks,
Scott - UberPacifica2005
Purge valve - Vacuum leak detection pump
Old Oct 3, 2020 | 06:36 PM
  #22
Hey Jeep Guy!
Need some help. I have ordered a new catalytic converter and want to know how to order the "correct" 02 sensors? First, I know it takes two on the 3.5, one before and after the converter. However, my concern is I will order two online only to find out they are not considered OEM and thus not recognized by the Pacifica's PCM.
Is this even an issue as I have heard before? Or if it is, how can I be sure I have ordered 02 Sensors that will function properly and clear the P0420 code and then the "Check Engine" light on the dash?
Thanks, open to ALL SUGESTIONS!
Thanks,
UberPacifica2005
Y4J
Jan 31, 2023 06:33 AM
Briarly
Dec 29, 2017 10:17 AM
fhadso
Dec 13, 2013 04:44 AM
wilson6107
Feb 27, 2011 07:10 PM
24todd
Feb 23, 2008 12:43 PM
