2005 Pacifica electrical issue
Old Apr 5, 2020 | 08:10 PM
MatthewJon's Avatar
Default 2005 Pacifica electrical issue
Hi, my mom has a 2005 Pacifica with an electrical issue. The other day, she took the dog for a ride and everything worked fine.
Today she goes out and her fob wouldn’t work and the car wouldn’t start. Turns out the battery was dead. I jumped it, then took it for about a 20 minute spin. Parked it, turned the key off, opened the door and the radio stayed on. The radio should turn off once the door is open, right?
Is there a switch in the door that could be causing an issue, or maybe a BCM? Something is draining the battery. I did check to see if she left the lights on, and they were off. Could a weak battery cause an issue like this?
Any ideas? Help is appreciated.
Matt
Old Apr 6, 2020 | 07:32 PM
djetelina's Avatar
Going to take someone with electrical experience to identify the root cause. Quite a bit involved, attached is a partial wiring diagram.
File Type: pdf
Old Apr 7, 2020 | 10:52 AM
ChryslerCares's Avatar
Matt
Hi, I'm sorry to hear this. Please let me know if you plan on visiting a dealership for this concern. I would be happy to open a case for you.
Alison
ChryslerCares
Old Sep 14, 2020 | 08:55 PM
MatthewJon's Avatar
Still dealing with the issue. With everything going on, haven’t spent much time working on the car.
I watched a good YouTube video about a Pacifica with tons of electrical gremlins. Turned out the issue was with a ground wire that was below the battery tray. I looked and the wires were crusty green, so I put on a new eyelet connector. That didn’t solve the issue.
So maybe the next step is looking at the drivers side door switch. I will let you all know what I find.
Old Oct 2, 2020 | 02:54 PM
jesoma's Avatar
Had the same problem, dead battery, had to recharge. I believe it's the ignition switch. To prevent it, I turn the car off and jiggle the key until radio goes off.
Old Aug 3, 2021 | 03:33 PM
Rich Ard's Avatar
Question Did you get this resolved?
Were you able to solve problem?
I have a parasitic draw and believe it's my ignition switch.
  • Just getting started to trouble shoot problem.
  • I will pull key from ignition and alarm rings as if key was left in ignition.
  • Giggle ignition with key and it stops.
Before I start trouble shooting my problem, was hoping to get insight from you if you were able to solve problem.
Thx
Rich Ard
Old Oct 4, 2021 | 06:09 PM
jesoma's Avatar
No never did any troubleshooting, car is old so I just do the jiggle thing, make sure radio goes off, and then pull the key. After repairing the problem with main ground wire issue, pain in the neck to get to, don't want to do time consuming fixes. (although maybe easy fix?)
Rct6
Jan 2, 2022 12:43 PM
RC193
Nov 14, 2015 09:24 PM
wiz kidd
Jun 17, 2014 06:41 PM
mrfixit454
May 7, 2009 12:48 PM
mcfishey
May 1, 2008 06:17 PM
