2009 T&C starting problem
Old Mar 14, 2020 | 12:57 PM
jimh12's Avatar
Question 2009 T&C starting problem
Have a 2009 T&C with 3.3L engine. Cant start the engine, when I put the key in and turn to START, starter works and turns engine over at normal cranking speeds but engine does not start.
When I release key from START position it returns to ON (engine doesn't start) but starter continues to crank. I have to return Key to OFF position to stop the starter. Battery is 7 months old,
I have kept it charged during this troubleshooting venture (with a battery charger). An OBDII scan indicates no Stored Trouble Codes and no Pending Trouble Codes. Does the starter motor
get switched off only when the vehicle engine starts or when you turn the ignition key to OFF? Will appreciate any clues or items to check. Thanks.
vpandita6
Oct 15, 2016 05:08 PM
daztray122
26
Jan 10, 2015 09:16 AM
mschaefe
May 21, 2014 03:44 PM
04_pacifica_4u
May 17, 2009 09:51 AM
golfdoctor3
Jan 19, 2009 11:11 PM
