HELP!! 2007 base t&c no interior lights, power at climate control
Old Dec 9, 2017 | 08:27 AM
Quickhick's Avatar
Default HELP!! 2007 base t&c no interior lights, power at climate control
Ok so i just bought this as is and have some un expected un mentioned problems ... no interior lights ,no dash lights , no power locks (so i cant open rear hatch) , the blower works fine but there is no power or lights on to blend door and position adjust . I could deal with these problems but the kids and ol lady are not very happy with the no heat. Was 20 degrees last night. Also worth mentioning it appears this was a taxi because it says so . When either slider is opened the hazards flash
Old Dec 9, 2017 | 10:42 AM
REBEL59's Avatar
Is the Check Engine Light illuminated? and have you at least checked for a blown fuse?
Old Dec 9, 2017 | 10:57 AM
Quickhick's Avatar
Default Yes
Yes i replaced the iod fuse and disconnected the battery and left it for a few hours with the terminals zip tied together no change . There is no power to the rear whiper or ac button neither light works radio is fine though
Old Dec 9, 2017 | 11:01 AM
Quickhick's Avatar
Default Yes
Engine light is on but for a 02 sensor . Guy says everything but the locks was working last time he drove it . Sat for a month in that time the battery was changed . Perhaps he shorted something ?
Old Dec 9, 2017 | 11:14 AM
REBEL59's Avatar
Does this have auto temp control HVAC system or manual slider/ **** controls? If ATC, it could have a bad control module mounted behind the glove box door. But I would be more concerned that power for dash/interior lights are working first. Recheck fuses, I had a van that had trailer wiring get shut in the rear hatch latch and shorted a fuse to power dash and lights.
Old Dec 9, 2017 | 11:57 AM
Quickhick's Avatar
It has ***** so atc? The heat is my biggest concern weather is heading in a few hours 3 inches of snow gotta have a defroster at least.
Old Dec 9, 2017 | 12:18 PM
My 2007 is a fourth generation model, yours may be different. On the fourth generation models there is a vertical rotary switch on the dash but near to the drivers door. This switches the interior lights ON/OFF/AUTOMATIC.
Attached Thumbnails HELP!! 2007 base t&c no interior lights,  power at climate control-dashboard-lhd.jpg
Old Dec 9, 2017 | 12:20 PM
Quickhick's Avatar
Dims the odometer and radio is all presently
Old Dec 9, 2017 | 12:40 PM
REBEL59's Avatar
You have manual HVAC(better deal,less costly). There is a reset procedure for the blend door and vent controls,Mine has the ATC, so I know there is one for your type also as I found it by Googling it for mine. Just can't remember where it is on the www, or the steps for your system. But if you find it ,it may be your "ticket" to a fix for you. Good Luck
Old Aug 9, 2019 | 11:22 AM
PeteOB's Avatar
Has anyone figured out how to recalibrate HVAC on the 4th Gen Sebrings yet?? (I am 2007)
Whiskeysix
Apr 2, 2018 04:58 PM
AlanC
May 27, 2015 02:43 AM
NicKeiRacing
15
Feb 19, 2012 09:08 AM
Kevolution
Jun 26, 2011 12:42 AM
22chrysler
Oct 28, 2009 12:52 PM
